Wifi Problem XR819
I have 4 Nanopi Duo. All devices have the same MAC address on the wifi interface: dc:44:6d:c0:ff:ee!
How can I change the address? I'm using the Ubuntu-distro.
Interactive working via ssh is a pain. The device is responding very slow, there are large latencies.
A small test with UDP Datagrams which are sent periodically (for example every 0.2 sec) shows, that the device receives them in chunks only every 1.84 sec!
Receiver on NanoPi:
import socket
import time
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
sock.bind(('',2222))
t0=time.time()
while True:
    m=sock.recvfrom(1024)
    t=time.time()
    print "%10.3f %5.3f %s" % (t,t-t0,m[0])
    t0=t
Transmitter external:
import socket
import time
UDP_IP = "192.168.1.166"
UDP_PORT = 2222
sock = socket.socket(socket.AF_INET,socket.SOCK_DGRAM)
for cnt in range(100):
    sock.sendto("%5d" % cnt, (UDP_IP, UDP_PORT))
    cnt+=1
    time.sleep(0.2)
when not using the network manager = using /etc/network/interfaces
you can configure the ethernet address via this interfaces file
like eth0 in the following sample:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
# clone mac address so we can get in net as instructed by IT
hwaddress ether XX:XX:XX:XX:XX:XX
https://askubuntu.com/questions/307717/networkmanager-problem-with-cloned-mac-address
see also
http://wiki.friendlyarm.com/wiki/index.php/Use_NetworkManager_to_configure_network_settings#1:_Setup_Static_IP_Manually
Receiver on NanoPi:
import socket
import time
t0=time.time()
while True:
    t=time.time()
    t0=t
import socket
import time
UDP_PORT = 2222
    cnt+=1
    time.sleep(0.2)
XR819 is a big challenge in NanoPI Duo.
It can not authenticate to non-password APs. too !
I have found a solution. MAC address is contained in the device tree.
Decompile device tree:
dtc -I dtb -O dts -o sun8i-h2-plus-nanopi-duo.dts sun8i-h2-plus-nanopi-duo.dtb
Modify mac address in line local-mac-address in section xr819wifi and compile device tree:
dtc -I dts -O dtb -o sun8i-h2-plus-nanopi-duo-a.dtb sun8i-h2-plus-nanopi-duo.dts
Put it back into boot directory. Reboot.
