HD Sata 2.5"
Good Morning!
I have a NanoPC T3 and I need to know if can I use a cable SATA to USB conversor to plug in NanoPCT3.
the cable comes with double usb, one to data transfer and another to power supply.
I intend to plug the data transfer USB on NanoPC T3 and the power supply usb on a source energy, becouse i think de NanoPCT3 can not supply energy the HD Sata.
Finally, my question is: can I do this? Can NanoPC T3 suport a HD Sata 2.5" 7200RPM 750GB?
Thankyou
Does anyone know the solution to my question?
If it helps, this is the cable I intend to use.
If you are running Linux why not just plug it in and see if it works?
It will or it won't and being USB it won't do any damage to your board if not.
