TFTP configuration
I am using PTXDIST.
I have to make a tftp server up on this board.
tftpd configuration file is as :
tftp dgram udp wait nobody /sbin/tftpd tftpd -l /var/tftp
I created a tftp folder in var folder
I Changed user to nobody
I changed permissions to 777
and whenever I am starting the tftp server as:
systemctl /etc/init.d/tftpd
It is throwing following error:
Failed to start etc-init.d-tftpd.mount: Unit etc-init.d-tftpd.mount failed to load: No such file or directory.
Any help or guidance is highly appreciated.
Thank You
I assume you ticked the right box in PTXdist for TFTP? I don't recall if there was more than one variant.
Yes, I ticked the right one. Can you just tell is this the error about the tftp folder permission ?
If it is that then how can I solve this problem.
