Matrix - 2'8 SPI TFT rotation
How set rotation on Matrix - 2'8 SPI TFT with buildin module. I try change cmdline
[root@localhost ~]# cat /proc/cmdline
console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait fsck.repair=yes panic=10 fbcon=map:0 fbtft_device.rotate=0
No result
Try change [root@localhost ~]# cat /etc/modprobe.d/fbtft.conf
options fbtft_device rotate=0
No result
Try echo 0 > /sys/class/graphics/fb1/rotate
No result
Always [ 2.096137] fbtft_of_value: rotate = 90
In boot console...
Ok i think i found solution. I use Debian image with 4.11 kernel
On boot partion i found sun8i-h3-nanopi-neo-core.dtb and conver it to sun8i-h3-nanopi-neo-core.dts with comand
/usr/src/linux/scripts/dtc/dtc -I dtb -O dts sun8i-h3-nanopi-neo-core.dtb > sun8i-h3-nanopi-neo-core.dts
in sun8i-h3-nanopi-neo-core.dts i found parametr rotation and change it to 0x00
convert dts to dtb with comand
/usr/src/linux/scripts/dtc/dtc -I dts -O dtb sun8i-h3-nanopi-neo-core.dts > sun8i-h3-nanopi-neo-core.dtb
and copy it to /boot partion
