Compilation environment for Neo2
Hi, I'm a very new to this board, I used the Intel Edison, but since it is discontinued I switched to Neo2.
I have an application written in C++, and I need to compile it and run on the NEO2.
Can anyone suggest what is the best way to do it. Maybe Eclipse?
I downloaded the ubuntu image nanopi-neo2_ubuntu-core-xenial_4.11.2_20170630
Which toolchain I should use?
Any tips will be highly appresiated!
Thanks in advance.
Just compile directly on the board. No need to use a cross compiler.
Thanks, that's what I'm doing right now, but is there any eclipse tutorial for this?
What is hte toolchain for compilation C&C++ on the board? Maybe I can setup some Qt or Eclipse environment for compilation?
Thanks for the command of this topic, thanks to that I got here. Cool thing.
