Device /dev/ttyUSB0 is missing (Nanopi Neo)
Hello. i get no /dev/ttyUSB0 which i want to use in node-red.
I use this image
http://wiki.friendlyarm.com/wiki/index. ... Image_Card
(Ubuntu core 16.04)
I have no idea, can anybody help me?
~$ lsusb
Bus 008 Device 008: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
~$ cat /proc/version
Linux version 4.11.2 (root@wwd) (gcc version 4.9.3 (ctng-1.21.0-229g-FA) ) #19 SMP Sat May 27 10:23:19 CST 2017
Note: With my tests with Jessy lite (DietPI) it works perfekt.
Thank you!
I have the same problem,
In my case:
lsusb
Bus 007 Device 002: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
and
$ uname -r
4.11.2
One clue could be that i could not find the library ftdi_sio
modprobe ftdi_sio
modprobe: FATAL: Module ftdi_sio not found in directory /lib/modules/4.11.2
In some forums i found that it could be solved by installing
sudo apt-get install linux-image-extra-virtual
but could not find that package.
Upbumping this topic as I too can't communicate with ttyUSB0 on nanoPi Neo. I am using the same ubuntu image as you guys (The one the pamphlet recommends that comes with the NEO)
It looks like the new kernel 4.x does not include anymore a lot of drivers that were previously included by default. The FTDI USB-Serial is one of them (ftdi_sio).
I've tried to download the sources and compile the drivers but when running (
make menuconfig
the option for the USB Serial drivers are also gone now. So I'm kind of stuck with the old kernel for the time.
I would also be interested if someone finds a way to install the drivers in the 4.x kernel.
