USB hat or prewired headers?
Are there are small form factor hats for NanoPi Neo that have extra USB ports, or are there any prewired USB sockets available that fit the expansion pins?
Thanks in advance.
NEO has 3 USB ports, one for Type-A, the other two by 2.54mm pin leads, you can see wiki tutorial on the definition of NEO pin:http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO
I am also looking for this. I would like a simple pcb with two style A usb connectors which plug into the expansion header.
Maybe I must make my own? Anyone interested in this?
If you need a customized service you can send email to FriendlyElc technical support mailbox :techsupport@friendlyarm.com
thank you!
