NanoPi NEO 2017-3-31 update firmware
Hi everyone,
1.Modify the Ubuntu-Core system login welcome interface, when the user logs will print the basic status of the system information.
2.Ubuntu-Core system to increase npi-config tool, npi-config is a command line under the system configuration tool, the system can be some initial configuration, configurable items include: user password, system language, time zone, Hostname, SSH switch , Automatic login options, etc., in the command line to execute the following sudo npi-config to enter
This is definitely not a fool's day joke :D , you can try to download the new firmware:
https://www.mediafire.com/folder/n5o8ih ... Nanopi-NEO
Thanks for pointing that out.
Though can someone from FriendlyArm confirm this? They are located in a different folder than the one that was referred in the wiki and that page (the wiki) does not seem to mention anything about the new functionalities.
Alex.
Alex.
Hi
The updated content has detailed steps in the wiki tutorial:
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO
