Got NanoPi NEO and the NanoHat PCM5102A But no pin headers!
Before when I got a NanoPi NEO it just auto came with all the pin headers and I could solder them in. But this time I really needed them because I got the NanoHat and can't plug it in with out them. But my order did not have them and looks like there is no way to even tell them to add that on to your order.
I went to radio shack today but they don't have them. I guess will look on line to order them.
I did solder 6 wires tight from the NanoPi NEO to the NanoHat. It plays but sounds bad. I guess it uses some other connections beside just the 6 on the one side.
Were is a place a can order a set of pin headers for the NanoPi NEO? Need to get the right pin spacing the size and all that.
Now got to wait longer to get this working good. Took about 3 weeks to get it from ordering it.
Hi, Raymond
Where do you live? let me see if there is some faster way to send to you the pin header.
We very sorry for cancelling this in the package because of the cost, We will check it and add it as an option ASAP.
Thank you
-- Mindee
I live in USA Michigan.
All the other orders I did came with the pin headers and I had to solder them in the NanoPi NEO and even the NanoPi Air.
My email address is : mindee.friendlyarm@gmail.com, and can try to arrange sending several pin header to you in USA via USPS from Seattle. Please send me your address.
Thank you
-- Mindee
Thank you just e-mailed you my address.
