USB Audio support
Dear FA support,
I work with Nano Pi2 for several projects. one of them needs audio and I want to play sound with cheap usb audio solution.
Unfortunately the Nano Pi2`s audio is routed to SPDIF transceiver in Debian GNU/Linux which is not mapped to I/O ports :( .
I searched many forums but seems that kernel should be compiled with some new modules.
I have installed most of ALSA libs but still need "snd_usb_audio" module and i can not find a way to add it to the kernel.
ALSAMIXER only detects SPDIF , also alsactl init command returns only SPDIF while a CM108 usb audio controller is plugged and lsusb returns correct hid of the usb card.
Do you have any idea for this problem ? Any guide for this ?
Thank you.
Have not tried this on NanoPi, but USB Audio support is a kernel option. Make menuconfig on the your kernel and turn it on.
Hi the SN_USB_AUDIO should be in our kernel. You can search again. I think you can just add that option in the menuconfig and recompile the kernel.
If you want to use audio for nanopi2 ,you can use USB audio chips
You can make debian kernel of nanopi2 ,and configure the kernel
config such as :
make nanopi2_linux_defconfig
make menuconfig
Device Drivers -->
Sound card support -->
--- Sound card support
[*] Preclaim OSS device numbers
<*> Advanced Linux Sound Architecture -->
--- Advanced Linux Sound Architecture
<*> OSS Mixer API
<*> OSS PCM (digital audio) API
[ *] OSS PCM (digital audio) API - Include plugin system
[* ] USB sound devices --->
<*> ALSA for SoC audio support --->
After compiling the kernel , you have to make sure your board can be
used internet , and do such steps to install the lib of audio:
#apt-get update
#apt-get install pulse-audio
#apt-get install libasound2
#apt-get install alsa-base
#apt-get install alsa-utils
Now you can play one music :
#aplay music.wav
If you want to use audio for nanopi2 ,you all can use USB audio chips
config such as :
make menuconfig
Device Drivers -->
<*> OSS Mixer API
#apt-get update
#aplay music.wav
