Nanopi R6S no longer displaying HDMI output, Unbrick failing
I was working on installing OpenBSD 7.7 on a Nanopi R6S. I was using the EDK2 firmware build on an SD Card and the OpenBSD installer on a USB Key to install the O/S on the EMMC. Things seemed to be working fairly well in that I was able to boot the installer using the HDMI framebuffer device (set tty fb0, followed by boot sd0a:/bsd.rd) and run through the install to write the O/S to the eMMC. However after rebooting, I seem to have lost all HDMI output. I don't even see the FriendlyElec firmware splash screen either. I tried to go through the brick recovery steps using maskrom mode and they seem to work at first.
# upgrade_tool ld
List of rockusb connected(1)
DevNo=1 Vid=0x2207,Pid=0x350b,LocationID=131 Mode=Maskrom SerialNo=
# upgrade_tool db MiniLoaderAll.bin
Download boot ok.
# upgrade_tool ssd
List of supported storage
No=1 FLASH
No=2 EMMC(*)
No=3 SD
No=4 SD1
No=5 SPINOR
No=6 SPINAND
No=7 RAM
No=8 USB
No=9 SATA
No=10 PCIE
Input No to switch,Quit press <Q>:qq
# upgrade_tool ef MiniLoaderAll.bin
Loading loader...
Start to erase flash...
Download Boot Start
Download Boot Success
Wait For Maskrom Start
Wait For Maskrom Success
Test Device Start
Test Device Fail
It looks like the device test is failing. Is there some way to obtain more information on what device tests are failing? Is the device permanently damaged or are there some other steps I can try to follow to recover the firmware so it will support the HDMI again?
If you don’t see even the firmware splash, it’s likely the bootloader in SPI or eMMC is corrupted. I would try flashing a full stock FriendlyElec image instead of just the MiniLoader and see if HDMI comes back.
Ah, thank you both for your encouragement and tips. I'll try to see if I can figure out how to do the full stock image re-flash.
In total there are 471 users online :: 0 registered, 0 hidden and 471 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 471 guests
