Fedora on NanoPC-T6-LTS
I'm sorry, no performance logs, as this forum does not allow text attachments.
No worries! Even without performance logs, the screenshot already gives a good overview. If you can, maybe share the key stats or error messages directly in the post text — that could help others understand the issue better.
No issue at all, everything is working as expected.
If there is still interest in metrics, you can take a look at the logs that I uploaded in this thread.
It's the same system on the same memory card, the NVME is just plugged in a different device. The difference lies only in the devicetree that is loaded at system startup. The log files are largely identical for all IPs they share.
In total there are 469 users online :: 0 registered, 0 hidden and 469 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 469 guests
