It has 8GB eMMC if SD card do it boot from that?
I forgot it had 8GB eMMC so I put a SD card on it with a image I downloaded. But I guess it don't boot from that but from the 8GB eMMC right?
Is there a way to get it to boot from the SD card?
If there's a working image on your SD, the NanoPi will boot from your SD card. (If this fails, the NanoPi tries to boot from eMMC.)
On http://wiki.friendlyarm.com/wiki/index. ... Pi_NEO_Air they say this:
Flash image to eMMC
and they say do this command:
eflasher
I had to reload mine because I first put it on a 200GB SD card. But I guess it can't see it all. So I used that card on a raspberry pi. Used a 128GB on it now. Having a hard time trying to get it on WiFi. Got it on RS-232 now.
Not sure how I got it on my WiFi before.
Can't find a link that says how to easy get it on WiFi got to do it on the command line and they don't have nano install have to use vi.
Not sure what did it. But I rebooted and it got a WiFi IP then.
Did dhclient wlan0 a lot of times waiting like 5 minutes for it and check it's ip with ifconfig. But it never got a IP. Till I rebooted it.
Here is my command line with my WiFi Password Xed out.
apt-get update
nmtui
df -h
eflasher
dhclient wlan0
ifconfig
iwconfig
cd /itc/init.d
cd /etc/
cd init.d
ls
nano /etc/init.d/wifi-on.sh
vi /etc/init.d/wifi-on.sh
cat /etc/init.d/wifi-on.sh
chmod 755 /etc/init.d/wifi-on.sh
update-rc.d wifi-on.sh defaults
cat /etc/init.d/skeleton
reboot
ifconfig
vi /etc/network/interfaces
cat /etc/network/interfaces
vi /etc/wpa_supplicant/wpa_supplicant.conf
cat /etc/wpa_supplicant/wpa_supplicant.conf
dhclient wlan0
iwlist wlan0 scan
dhclient wlan0
ifconfig
cp /etc/network/interfaces /etc/network/interfaces~
dhclient wlan0
ifconfig
nmcli c
iwconfig wlan0 essid Linksys01953_V2 key xxxxxxxxxxxxxxxxxxxxxxxxxx
dhclient wlan0
ifconfig
iwconfig wlan0 essid Linksys01953_V2 key s:xxxxxxxxxxxxxxxxxxxxxxxxxx
dhclient wlan0
ifconfig
wpa_passphrase Linksys01953_V2 xxxxxxxxxxxxxxxxxxxxxxxxxx
dhclient wlan0
ip link set wlan0 down
ip link set wlan0 up
wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant.conf -Dwext
nmcli d wifi connect Linksys01953_V2 xxxxxxxxxxxxxxxxxxxxxxxxxx iface wlan0
add_network
iwconfig wlan0 essid Linksys01953_V2 key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
iwlist wlan0 scan
iwconfig wlan0 ap C0:56:27:6D:C5:18
iwconfig wlan0 freq 2.437G
dhclient wlan0
dhclient wlan0
iwconfig
ifconfig
reboot
It's junk the wiki says do a apt-get when you don't have WiFi working 1ST!
This time is was easy to get the camera working it it.
https://goo.gl/photos/QjxAZXsorwgSB2bd7
That's a screen shot of the webpage to the camera on it and got a photo of it's self with it.
This has to be running to use it.
root@FriendlyARM:~/mjpg-streamer# ./start.sh
MJPG Streamer Version: svn rev:
i: Using V4L2 device.: /dev/video0
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 30
i: Format............: YUV
i: JPEG Quality......: 90
o: www-folder-path...: ./www/
o: HTTP TCP port.....: 8080
o: username:password.: disabled
o: commands..........: enabled
It was easy this time to get it working.
