FriendlyARM NanoPi M4 RK3399 not booting
I'm trying to install LibreElec on FriendlyARM NanoPi M4 RK3399 but I'm not seeing anything boot.
When powering the device nothing happens - no LEDs, no HDMI output.
I am certain that the device is functional - it was running Armbian just before and I've also successfully installed DietPi.
Help is appreciated!
Thanks in advance
Thanks in advance
It sounds like the boot process might be failing. You can check:
Verify the Image: Ensure the LibreELEC image is specifically built for RK3399 and compatible with the NanoPi M4.
Reflash the SD Card: Try using tools like Etcher or Rufus to flash the image again.
Check Power Supply: Confirm your power supply provides stable 5V/3A, as the RK3399 can be power-hungry.
Reset and Recovery: Try holding the MaskROM or Recovery button (if available) during boot to force recovery mode.
Serial Console: Connect a USB-to-TTL adapter to monitor serial output for more insight into boot issues.
If none of these work, consider testing with a minimal Linux image to ensure the hardware is still functional.
Thanks in advance
Make sure the LibreElec image is compatible and correctly flashed. Check the microSD or eMMC connection, use a reliable power adapter, and try accessing UART for debug messages.
Hope this helps.
If there's no LED or HDMI output, it might be:
Image Compatibility: Ensure the LibreELEC image supports NanoPi M4.
SD Card Issue: Try reflashing using balenaEtcher or Rufus.
Power Supply: Confirm it's providing stable power.
Hardware Check: Connect via UART for debug messages.
Hope this helps.
