Problem with static IP
I don't have dns resolution follow wiki instruccions on Debian.
The image I used is: rk3528-eflasher-debian-bookworm-core-6.1-arm64-20241112.img
I use this wiki page for configuration: https://wiki.friendlyelec.com/wiki/inde ... he%20steps
I put ip addres without problems (point 5.3.1), but dns (point 5.3.2) don't work. My file /etc/systemd/resolved.conf is correct, but I don't able to make a simple ping to anyone. If I try to change /etc/resolv.conf, this file is rewriten ech time the system start.
Any suggestions?
Thanks in advance
I ran into the same problem yesterday. Even though I'm pretty much a Linux novice, I've discovered the issue.
It only took me, oh, at least 3 hours of trying, failing, trying again, and discovering the issue by chance. :oops:
It's with /etc/systemd/resolved.conf.
This is not the correct file name.
This is not the correct location.
The code example given does not have the correct syntax.
WRONG command: vi /etc/systemd/resolved.conf
CORRECT command: vi /etc/resolv.conf
The filename is slightly different and one level higher up in the directory structure.
WRONG content:
[Resolve]
DNS=192.168.1.1
CORRECT content:
[Resolve]
nameserver 192.168.1.1
