Debian CM3588 - Fan control settings
Hello, I have recently acquired a CM3588 board. I have successfully installed debian with the provided image:
rk3588-eflasher-debian-bookworm-core-6.1-arm64-20240522.img.gz
Setting up ZFS with 4 SSD slots was easy following this great guide:
https://github.com/DukeChocula/CM3588
However, I have noticed the fans are not engaging although the board gets quite hot. I have tried enabling fan control by following this SO answer:
https://askubuntu.com/questions/22108/h ... -fan-speed
However the
sensors-detect
command fails to detect any devices:
Sorry, no sensors were detected.
Either your system has no sensors, or they are not supported, or
they are connected to an I2C or SMBus adapter that is not
supported. If you find out what chips are on your board, check
https://hwmon.wiki.kernel.org/device_support_status for driver status.
Any tips or information regarding the status of fan control?
Did you checked this post : viewtopic.php?f=81&t=4141
Is the only solution to use the GPIO pins? I spliced the tiny connector into the 80mm fan I bought for the case and it works with the Debian install the OP also used, but not until CPU0 hits 50C. I'd just like to be able to adjust that fan curve a little. But I can't find anything anywhere on the fan controller, pwmconfig doesn't even seem to be installed by default.
In total there are 67 users online :: 0 registered, 0 hidden and 67 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 67 guests
