NEO CORE eflasher problem
Hi, everyone.
I'm trying to boot nanopi neo core with FreeBSD 13.2.
I made an sd card image of freebsd img file, and succedded to boot it from sd card.
It works until now. I did not test some sensors though.
Now, I am struggling to install my bootable image to emmc.
But there is no proper document or tutorial for this task.
I found some eflasher documents from official website and github, but it may look like for linux.
Is there any tips or helps to flash non-linux os image to emmc?
Thanks.
I booted neo core board with FreeBSD sd card image,
and I cooked the emmc with FreeBSD 13.2 image manually by using dd.
It is working now. FreeBSD in emmc can boot with ethernet.
It looks like working with Bakebit Hub. I tested just Bakebit-LED with the Hub.
I booted the Neo Core board with the FreeBSD SD card image and manually cooked the emmc with FreeBSD 13.2 using dd.
It's now functioning. FreeBSD in emmc can boot via Ethernet.
It appears to be compatible with Bakebit Hub. I only tested the Bakebit-LED with the Hub.
hill climb racing
