LCD2USB two function keys how?
Hi I got the LCD2USB and it's working good showing the IP and time.
But on the wiki it says "It has two function keys which can be configured by users." but it don't say how.
Any one know how to make it use the 2 keys on it. I guess to show some other display and then maybe safely shut it down too. Something like that.
On this web page it says a one line about the buttons but does not show how that I can see. The one line says this:
Also two detectable input buttons, generally called key-a and key-b on board.
I think it be neat to press one of the buttons to change the display to something else.
A 4 line LCD works with this. I got it working now.
This my help soma else the code at /etc/lcd4linux.conf file mine looks like this:
Variables {
   tick 500
   tack 100
Display LCD2USB {
    Driver 'LCD2USB'         #Model: LCD2USB
    Size '20x4'            #LCD dimension: 2004
    Backlight 0
    Icons 1
Widget IPaddress {
    class 'Text'         #Type: Text
    expression netinfo::ipaddr('eth0')   #eth0's ip
    prefix 'IP: '         #display "IP: "
    width 20            #display width: 19
    align 'C'            #display: center
    update 1000
Widget Time {
    class 'Text'
    expression strftime('%a %I:%M:%S %p',time())
    width 20
    align 'C'
    update 1000
Widget Busy {
    class 'Text'
    expression proc_stat::cpu('busy', 500)
    prefix 'Busy '
    postfix '%'
    width 10
    precision 1
    align 'R'
    update tick
Widget BusyBar {
    class 'Bar'
    expression2 proc_stat::cpu('system', 500)
    length 10
    direction 'E'
    update tack
Widget Load {
    class 'Text'
    expression loadavg(1)
    prefix 'Load '
    postfix loadavg(1)>1.0?'!':' '
    width 10
    precision 1
    align 'R'
    update tick
Widget LoadBar {
    class 'Bar'
    max 2.0
    length 10
    direction 'E'
    update tack
Layout Default {
    Row1 {
        Col1 'IPaddress'      #Display Widget IPaddress in the first row and first column
    Row2 {
        Col1 'Time'         #Display Widget Time in the second row and first column
    Row3 {
   Col1 'Busy'
   Col11 'BusyBar'
    Row4 {
   Col1 'Load'
   Col11 'LoadBar'
Display 'LCD2USB'
Layout  'Default'
It shows the IP, time, Busy and load on the 4 lins. The load is how many programs are running.
Now just need to know how to program the buttons.
On that code change the timeline to this so can have AM and PM and not 24 hour time.
Just had to add the %p' at the end. I edit the whole lcd4linux.conf in here so it does the AM PM now. So this file goes in /etc/lcd4linux.conf.
I like it better like that.
When I did a stress test and got this photo of the 4x20 LCD display.
https://photos.app.goo.gl/8mTar4TquvCTtVcS9
Just so people know what it looks like.
But I guess if would get the 2 buttons working could change the display to something else.
Still don't know how to get the 2 buttons to work on it. Be nice to press them for other display info.
