rk3328-sd-friendlywrt-5.10-20210305.img fails to boot
I just flashed the new image ( rk3328-sd-friendlywrt-5.10-20210305.img ) to an 8GB card. This image fails to boot. The red power light comes on and I get no further indication of activity. Anyone else had this issue?
What does the debug output show? That is the best way to know what has happened.
Doesn't Give any output at all. Red light comes on. No further activity. Re-flash same SD with rk3328-sd-friendlywrt-5.10-20210114.img and all ok. Downloaded rk3328-sd-friendlywrt-5.10-20210305.img again and flashed the same sd card get the same result no activity. I noticed that looking in the partition table of the new image in gparted that it has 9 partitions compared to 2 partitions in older version and standard open-wrt. Gparted sees the first 7 partitions as non standard and is unable to mount them.
Hello Friends
Also have the same problem, with the recent image albeit.
How did you solve it ?
Regards
J
