How to cross compile qt +opencv using sdk
Sir i need steps to cross compile opencv+qt
i am able to run qt+opencv on my pc but when i cross compile to nano pc board its showing error.
PC os is ubuntu 16.04
QT version 15.09.1
board os is 16.04.6
image used :s5p4418-sd-friendlycore-xenial-4.4-armhf-YYYYMMDD.img.zip
i need sdk to cross compile bot qt and opencv
The do_populate_sdk task knows the target and will install the needed 9apps headers and libs on the respective sysroot.
