New release '16.04.7 LTS' available.but can't.
Hi when I log in to my nanopi-neo it says this.
login as: root
root@nanopi-neo's password:
Welcome to Ubuntu 15.10 (GNU/Linux 3.4.39-h3 armv7l)
 * Documentation:  https://help.ubuntu.com/
Your Ubuntu release is not supported anymore.
For upgrade information, please visit:
http://www.ubuntu.com/releaseendoflife
Run 'do-release-upgrade' to upgrade to it.
root@NanoPi-NEO:~#
It goes thought a lot but then says Aborting and never upgrades.
Is there a way to upgrade it?
No.
No Good to know I was working on it for 2 days. Thank you.
This has so little ram only 512GB it can lock up on some things the fix is make the swap bigger and get a Max Endurance SD card.
sudo swapoff -a
sudo dd if=/dev/zero of=/swapfile bs=1M count=1024
sudo chmod 600 /swapfile
sudo mkswap /swapfile
sudo swapon /swapfile
sudo swapon --show
echo '/swapfile none swap sw 0 0' | sudo tee -a /etc/fstab
Or a one line command:
sudo swapoff -a && sudo dd if=/dev/zero of=/swapfile bs=1M count=1024 && sudo chmod 600 /swapfile && sudo mkswap /swapfile && sudo swapon /swapfile && sudo swapon --show && echo '/swapfile none swap sw 0 0' | sudo tee -a /etc/fstab
But the
Not enough free disk space
The upgrade has aborted. The upgrade needs a total of 193 M free
space on disk '/boot'. Please free at least an additional 165 M of
disk space on '/boot'. You can remove old kernels using 'sudo apt
autoremove' and you could also set COMPRESS=xz in
/etc/initramfs-tools/initramfs.conf to reduce the size of your
initramfs.
Restoring original system state
Aborting
Can fix this making a boot out side that small petition. Next image they do should make that boot partition bigger to get around it can do this:
mkdir /mnt/boot_temp
cp -r /boot/* /mnt/boot_temp
umount /boot
mount --bind /mnt/boot_temp /boot
Then can do the do-release-upgrade
say N to not reboot because have to mount /boot and then cp -r /mnt/boot_temp/* /boot
Then can reboot.
Hope they fix this in the next version. I downloaded h3-sd-friendlycore-focal-4.14-armhf-20240818.img.gz put it on a Max Endurance SD card and have to run 2 do-release-upgrade that you should do before setting any other things up.
Hope this helps some one it would of me when I posted for help about this.
It be neat if they came out with a 4GB RAM NanoPi NEO. All so A updated image.
