Nanopi neo air with CAM00A module error.
I flashed 20160927-nanopi-air-eflasher-sd8g-20160927.img
and following the wiki guides.
I eflashed the ubuntu images to emmc.
I got the below messages
[OV5640]error at sensor_detect
[OV5640]chip found is not an target chip.
in dmesg.
and then make and ./mjpeg-streamer/start.sh
MJPG Streamer Version: svn rev: Unversioned directory
i: Using V4L2 device.: /dev/video0
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 30
i: Format............: YUV
i: JPEG Quality......: 90
ERROR opening V4L interface: No such file or directory
Init v4L2 failed !! exit fatal
i: init_VideoIn failed
How can I work with my CAM500A module?
Hi, yoonts,
On the CAM500A pcb, remove R6, solder R5 with a 0ohm resister.
yonganch wrote:
Hi, yoonts,
Very good!
Working well.
Thanks.
