How to check if my Neo is V.1 or V1.1 ?
I have a bunch of V1 NEO on my desk and recently ordered a new batch I presume is V1.1.
How can I visually identify the different versions ?
Cheers,
This is v1.1, with the new 5 Audio pins on left bottom corner:
v1.0 does not have the 5 Audio pins.
Hermann.
According to the schematic, con2 (1x12) bonds out USB and audio. According to the site, con2 bonds out usb and i2c. Which is correct? Is audio available without using the 2mm 5 pin connector?
Hi All,
About the Hardware_Differences_Among_Different_Versions of the NanoPi NEO , you can see this link which has detailed introduction : http://wiki.friendlyarm.com/wiki/index. ... t_Versions
thank you!
