How to install docker-compose
What is the correct way to install docker-compose?
I wasn't able to get docker-compose running using any of the instructions at https://docs.docker.com/compose/install/
But it works when using linuxeserver.io's docker-compose image. It can easily be installed with
wget https://raw.githubusercontent.com/linuxserver/docker-docker-compose/master/run.sh -O /usr/bin/docker-compose
chmod +x /usr/local/bin/docker-compose
Thanks. I found some of these notes as well:
https://openwrt.club/95.html
https://forum.openwrt.org/t/docker-comp ... nwrt/60699
This script should build docker-compose successfully:
https://gist.github.com/CRFSlick/ba518c ... 7c52a4a62a
