npi-config missing
Hello, I recently got a Neo3 and I noticed that the npi-config is not available in the provided core download. Will it be added in the future?
Thank you
I just ran into the same problem. How do I install it?
Yes. I also noticed this and wondered if there is an equivalent for this platform. Does anyone at FA check this forum?
I am appalled by the lack of support for this product... The software side of NanoPi seems to be totally up in the air. Not a board for makers. Ok only if you want to use an already made software. Forget about using UARTs other than the debug serial, GPS with PPS... no documentation, no support...
E.
