Swap in Debian kernel...
Swap is currently disabled in the default Debian kernel. Is it easy to enable it, or is it disabled because it doesn't work?
Try <swap debian> on the old forum.
dd if=/dev/zero of=/var/swapfile bs=1M count=128
chmod 0600 /var/swapfile
mkswap /var/swapfile
swapon -f /var/swapfile
1. Using the above commands can create a 128M size file as swap,you can change the size with the first command,after that you can use free command to check whether uses swap.
2. You should use the kernel which have opened to replace the SD card‘s, then you can type the above commands.
