Android
I copied the disk image to a 16G card and inserted it, it power up and says "Freindly Arm" then it says "Nexell" then it boots and seems to reset and says "Freindly Arm" again, it does this a few times and eventually Android starts, but it is very bad, why is it doing this?
Richard.
Hi did you use the NanoPC-T1 or Tiny4412? Could you help collect your system messages and post them here? You can do it in Android's ADB shell , dmesg
Richard.
I think your problem Solved currently, if you have any issue than I will resolve your problems.
