RK3399 Android 8.1 LTE to WIFI Handover Failed
Hi All
During LTE module test I found an issue regarding LTE to WIFI Handover problem.
When both WIFI and LTE are connected, The handover from WIFI to LTE works fine.
However the problem occurred when disable LTE and turn on WIFI.
The WIFI signal become too weak to find available AP. The symptom is still reproducible even after reboot. and power on-off while the LTE module is connected.
Then the LTE module is disconnected, and retry turn on the WIFI.
Finally WIFI become normal showing strong signal strength.
The problem could be resolved by disconnecting LTE module physically from port.
I supposed the handover request could not happen if the LTE module is still connected after activating LTE networking.
Does anyone have an idea how to resolve this handover issue when disable LTE in setting menu. and the turn on WIFI again?
Without physically removal of LTE module from the port, The LTE-WIFI handover is not successful.
Thanks.
Best Regards,
JK
Handover delay is one of the imperative issues in remote and versatile system correspondences. Astounding endeavors were finished by analysts to plan a reasonable answer for limit the handover delay. The repetitive handover is happened when the handover procedure with another station is uncompleted while the handover choice happens. The expectation procedure could be useful in tackling this issue.
Kodi nox
The issue you are encountering with LTE to Wi-Fi handover when disabling LTE and turning on Wi-Fi seems to be specific to the device and its network configuration.
Delete and re-create your Wi-Fi network profiles on the device. Sometimes,iphone file browser mac network profiles can become corrupted, leading to connectivity issues.
