SSH Login without knowing IP Address
HI ,
How can I login to Core 2 using SSH without knowing IP address like Raspberry Pi ?
In case of Raspberry Pi , I can use ssh pi@raspberrypi.local . without knowing its IP address.
nitipongs wrote:
HI ,
Here you can do this as well. If you install AVAHI. Otherwise this way: https://docs.armbian.com/User-Guide_Get ... w-to-login
