rtl8812au (netis wf2190) install on ubuntu core 3.14.29
I'm trying to install rtl8812au drivers to run my netis WF2190 Wirelesss network card and have big problems with that.
I tried:
1. Upgrade ubuntu_core from 3.14.29 to sth 4.4.x - no luck because using aptitude and install linux-generic and dependencies process stucked saying root device not found.
2. Install from dkms - no kernel sources found and it's already in dkms repository
3. Trying to install from source of drivers given by manufacturer Support Ubuntu-16.04/4.4.0
http://www.netis-systems.com/Suppory/de ... de/96.html
so downloaded drivers, unpacked chmod a+x install.sh -> so run it with sudo ./install.sh
Ther result is:
Authentication requested [root] for make driver:
make ARCH=aarch64 CROSS_COMPILE= -C /lib/modules/3.14.29/build M=/home/pi/RTL8812AU_linux_v4.3.20_16317_20160108/driver/rtl8812AU_linux_v4.3.20_16317.20160108 modules
make[1]: *** /lib/modules/3.14.29/build: No such file or directory. Stop.
Makefile:1656: recipe for target 'modules' failed
make: *** [modules] Error 2
Compile make driver error: 2
Please check error Mesg
Here is my question:
pi@NanoPi-K2:~/RTL8812AU_linux_v4.3.20_16317_20160108$ cd /lib/modules/3.14.29
pi@NanoPi-K2:/lib/modules/3.14.29$ ls -l
total 80
lrwxrwxrwx 1 root root 32 Jul 17 2017 build -> /home/FriendlyARM/upstream/linux
drwxr-xr-x 2 root root 4096 Jul 17 2017 extra
drwxr-xr-x 3 root root 4096 Jul 17 2017 kernel
-rw-r--r-- 1 root root 527 Jul 17 2017 modules.alias
-rw-r--r-- 1 root root 609 Jul 17 2017 modules.alias.bin
-rw-r--r-- 1 root root 15205 Jul 17 2017 modules.builtin
-rw-r--r-- 1 root root 18593 Jul 17 2017 modules.builtin.bin
-rw-r--r-- 1 root root 129 Jul 17 2017 modules.dep
-rw-r--r-- 1 root root 250 Jul 17 2017 modules.dep.bin
-rw-r--r-- 1 root root 52 Jul 17 2017 modules.devname
-rw-r--r-- 1 root root 95 Jul 17 2017 modules.order
-rw-r--r-- 1 root root 131 Jul 17 2017 modules.softdep
-rw-r--r-- 1 root root 889 Jul 17 2017 modules.symbols
-rw-r--r-- 1 root root 1103 Jul 17 2017 modules.symbols.bin
lrwxrwxrwx 1 root root 32 Jul 17 2017 source -> /home/FriendlyARM/upstream/linux
how correctly fill the content of /home/FriendlyARM/upstream/linux??? because links are marked red color and path /home/FriendlyARM/upstream/linux does not exists. It's fresh install with updates
pi@NanoPi-K2:/lib/modules/3.14.29$ uname -a
Linux NanoPi-K2 3.14.29 #8 SMP PREEMPT Sat Apr 15 21:13:15 HKT 2017 aarch64 aarch64 aarch64 GNU/Linux
Please help
rjaszek wrote:
Please help
1. Download https://www.armbian.com/nanopi-k2/ and install variant you need
2. Plug your wireless and enjoy ~153-200 MBits/s with monitor mode and frame injection
3. Say thanks https://www.armbian.com/donate :)
