USB to IP redirect
Hi everybody
There is well-known software for x86 processors. It consists of a usbip utility, usbip-core and usbip-host lkernel modules and usbipd daemon. This software is installed by the "apt-get install linux-tools-"kernel version" command. Is there the same software for nanopi neo2? I did not find anything. Maybe badly searched?
Help me please.
bigbeer wrote:
Hi everybody
Help me please.
on armbian I did only find the usbip-package:
root@npi-neo2 :~# uname -a
Linux npi-neo2-24 5.5.0-sunxi64 #trunk SMP Mon Feb 17 18:21:22 +03 2020 aarch64 GNU/Linux
root@npi-neo2 :~# apt-cache search usbip
usbip - USB device sharing system over IP network
maybe there is more if I had the Linux-headers installed?
Thank you. You did my search in the right direction.
This is output "apt-cache search usbip":
libusbip-dev - USB device sharing system over IP network (development files)
libusbip0 - USB device sharing system over IP network (shared library)
usbip-source - USB device sharing system over IP network (kernel module source)
If I understand correctly, kernel modules only exist in the source code and need compilation?
you can check that if you only install usbip - if you could fine then the complied modules on your system.
It look like this package does have the modules compiled from the source-package.
That is what I found out:
1. There is a USBIP utility and a USBIPD daemon on my FrienlyELEC.
2. When daemon starting up:
fa@NanoPi-NEO2:~$ sudo usbipd -D
usbip err: stub_driver.c:  33 (open_sysfs_stub_driver) usbip_common_mod.ko and usbip.ko must be loaded
** (process:29628): ERROR **: driver open failed
Trace/breakpoint trap
Ok, try loading kernel modules:
fa@NanoPi-NEO2:~$ sudo modprobe usbip_common_mod
modprobe: FATAL: Module usbip_common_mod.ko not found in directory /lib/modules/4.14.111
and
modprobe: FATAL: Module usbip.ko not found in directory /lib/modules/4.14.111
Thus, there are no suitable kernel modules on my system. Compilation from source is higher magic for me :).
... which is why Armbian exist.
You can download ready made images (they are significantly higher quality)
https://www.armbian.com/download/?tx_maker=friendlyelec
or build your image / kernel without any higher magic:
Thank you i will try it.
There are two Armbian's builds - Bionic and Buster
Let's start with Bionic:
root@nanopineo2:~# apt-get install usbip
Reading package lists... Done
Building dependency tree
E: Unable to locate package usbip
root@nanopineo2:~# apt-get install linux-tools-5.4.20-sunxi64
E: Unable to locate package linux-tools-5.4.20-sunxi64
E: Couldn't find any package by glob 'linux-tools-5.4.20-sunxi64'
E: Couldn't find any package by regex 'linux-tools-5.4.20-sunxi64'
Fail. No packages in Bionic.
But there is a suitable package "USBIP" in Buster repository.
Install and run:
root@nanopineo2:~# modprobe usbip-core
root@nanopineo2:~# modprobe usbip-host
root@nanopineo2:~# modprobe vhci-hcd
root@nanopineo2:~# usbipd -D
root@nanopineo2:~# usbip list -l
 - busid 3-1 (12d1:1446)
   Huawei Technologies Co., Ltd. : HSPA modem (12d1:1446)
root@nanopineo2:~# usbip bind -b 3-1
usbip: info: bind device on busid 3-1: complete
That's what we need. USB device sharing server started up.
Install and run:
Great!
This is yet another example of why we provide both Debian and Ubuntu under the same kernel. Its hard and expensive to catch and patch things like this. If one doesn't work, other will :)
