NanoPi M4V2 heat sink mounting holes
I'm putting together a NanoPi M4V2 based NAS and would like to check case options.
Does anybody know (or can anybody measure) the dimensions of the mounting holes on the M4V2 heat sink? Any chance some of the 6 holes on the top of the heat sink match mounting holes on 2.5 inch hdds /ssds?
Ladde
those 6 holes are 40mm apart on the long side (3 of them) and 50mm apart on the short side (2 of them)
they don't line up with ssd drives.
I'd look into using the 1/4" 'camera' mounts for any custom rig, these are versatile due to the wide range of camera equipment that use this type of mount.
good luck.
