How can I play an MP3?
I am sitting here at the root prompt on a Nanopi NEO with Ubuntu 15.10 loaded from the FriendlyARM file.
I can get sound by running the speaker-test program, but I cannot play MP3 files.
I have downloaded and built mpg123 but all it does is complain that it cannot open the default sound device.
For people who CAN play MP3's on this hardware, with this O/S, how did you do it,please?
So you have connected speaker already and it gives sound.
Try "omxplayer -p -o local song.mp3", it worked for me on Pi Zero [I posted on "seeing" sound via oscilloscope, but later I connected earphones and could hear the music (badly because I did it without diodes and capacitors as described in Adafruit posting)]. Maybe "Changing the GPIO ALTs" from that posting is needed on NanoPi Neo as well.
Usage: omxplayer [OPTIONS] [FILE]
Options :
         -o / --adev  device            audio out device      : e.g. hdmi/local
         -p / --passthrough             audio passthrough
Hermann.
https://twitter.com/HermannSW/status/761354223300861952
Thank you. Unfortunately the "Pi" family is a very different beast from the H3-based NanoPi devices - despite a slight similarity in the name.
FriendlyARM-root: omxplayer
-bash: omxplayer: command not found
FriendlyARM-root: apt-get install omxplayer
Reading package lists... Done
Building dependency tree
E: Unable to locate package omxplayer
The thing that crushes the Nano*** devices and it would appear all the H3 boards is the lack of software and libraries. So although the hardware is great and the price is excellent, when you cost-in the time needed to get anything to work, they fall behind. Because they are different from Pi's, it's not such an easy thing to simply port stuff across.
You are right.
Recently I learned how to install more that can be done by default on Nanopi Ubuntu in this posting:
http://www.friendlyarm.com/Forum/viewtopic.php?f=49&t=206&p=765#p765
I did that on one of my Nanopi Neo, but omxplayer could not be installed. I do not remember whether it could be installed on Raspberry Pi Zero via apt-get, or whether I built it. Just cloned it from github:
https://github.com/popcornmix/omxplayer
Executed "./prepare-native-raspbian.sh" as being told in README.md and then did "make ffmpeg". After quite some downloads ffmpeg's "configure" errors out:
      --enable-decoder=opus \
      --cross-prefix=arm-linux-gnueabihf-
arm-linux-gnueabihf-gcc is unable to create an executable file.
C compiler test failed.
So for playing mp3 on Nanopi M1/Neo you need to do the Wily changes from the posting I pointed to, and then try one of the players returned by "apt-cache search mp3".
Or you start with playing .wav files with installed "aplay".
Hermann.
I finally found a way to play MP3 songs on Nanopi Neo!
I had not so good experiences with ffmpeg on other computers in the past.
But I just followed the instructions on this page and all was fine:
https://trac.ffmpeg.org/wiki/CompilationGuide/Ubuntu
I had to "configure" with leaving out two libraries I could not find or install:
apt-get -y install autoconf automake build-essential libfreetype6-dev   libsdl1.2-dev libtheora-dev libtool libvdpau-dev l
ibvorbis-dev libxcb1-dev libxcb-shm0-dev libxcb-xfixes0-dev pkg-config texinfo zlib1g-dev
Then for MP3 support what is described under section "libmp3lame" without any problems.
And finally "ffmpeg" compilation leaving out the libraries I had not installed, but including "libmp3lame":
PATH="$HOME/bin:$PATH" PKG_CONFIG_PATH="$HOME/ffmpeg_build/lib/pkgconfig" ./configure   --prefix="$HOME/ffmpeg_build"   --pkg-config-flags="--static"   --extra-cflags="-I$HOME/ffmpeg_build/include"   --extra-ldflags="-L$HOME/ffmpeg_build/lib"   --bindir="$HOME/bin"   --enable-gpl   --enable-libfreetype   --enable-libmp3lame   --enable-libtheora   --enable-libvorbis   --enable-nonfree
And then I played the first MP3 song, without any high or low pass filters with really good headphone sound quality(!). I just checked same song with omxplayer on Raspberry Pi Zero, and I can identify the song, but quality is really bad. That seems to be the reason why in Adafruit posting pointed to further above they did use high/low pass filters. Maybe Nanopi Neo has the needed filter already built in?
root@FriendlyARM:~/ffmpeg_sources/ffmpeg# ./ffplay ../../Porcelain.mp3
ffplay version N-81451-g8a78fc5 Copyright (c) 2003-2016 the FFmpeg developers
  built with gcc 5.2.1 (Ubuntu 5.2.1-22ubuntu2) 20151010
  configuration: --prefix=/root/ffmpeg_build --pkg-config-flags=--static --extra-cflags=-I/root/ffmpeg_build/include --extra-ldflags=-L/root/ffmpeg_build/lib --bindir=/root/bin --enable-gpl --enable-libfreetype --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-nonfree
  libavutil      55. 29.100 / 55. 29.100
  libavcodec     57. 54.100 / 57. 54.100
  libavformat    57. 48.100 / 57. 48.100
  libavdevice    57.  0.102 / 57.  0.102
  libavfilter     6. 54.100 /  6. 54.100
  libswscale      4.  1.100 /  4.  1.100
  libswresample   2.  1.100 /  2.  1.100
  libpostproc    54.  0.100 / 54.  0.100
Input #0, mp3, from '../../Porcelain.mp3':    0KB sq=    0B f=0/0
  Metadata:
    title           : Porcelain
    artist          : Moby
    album           : Play
    date            : 2004
    comment         : Amazon.com Song ID: 20796195
    track           : 3
  Duration: 00:04:00.27, start: 0.025057, bitrate: 210 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 210 kb/s
    Metadata:
      encoder         : LAME3.97
    Side data:
      replaygain: track gain - -7.000000, track peak - unknown, album gain - unknown, album peak - unknown,
The good sound was made possible by this new "finger adapter" for the headphones ;-)
Have fun with NanoPi Neo MP3 playing,
Hermann.
Youtube video -- even with volume reduced to 50% it is so loud ;-)
'Nanopi Neo "ffplay"s MP3 via PAM8403 Stereo Audio Amplifier on 89 dB 8 Ω 3W loudspeakers'
phpBB [video]
Hermann.
Today my new (13$) Nanopi M1 arrived, only 13 days after order ;-), and a heatsink for one of my Nanopi Neos.
I removed SD card from one of the Neos and inserted into M1 (they use same OS image).
Then I powered M1 via GND/5V via UART pins (micro USB is definitely possible as well).
And I plugged in earphones into 3.5 audio jack and started "ffplay" as above.
I got good quality MP3 sound immediately on the earphones, as long as I started with volume ≤0.5 ;-)
Hermann.
it's working!!!!!
phpBB [video]
Hi all,
Would you please tell to me how you get sound from Neo? :(
i don't know what configuration needed to play sound or record test. :(
is this necessary to use PAM8403 module? I mean can we connect LineR & LineL of Neo , directly to a simple earphone ( without PAM8403 module)?
what about record sound?
I mixed up :roll:
I will appreciate if someone give a simple schematic or a picture of connections.
Thanks. :)
either with headphones or with amplifier and loudspeakers.
you need some tool to play sound, "ffplay" allows to play .mp3 sound.
no.
Yes, see "finger adapter" photo in this posting above (I do have two v1.0 Neos, pins are different for v1.1 Neo):
http://www.friendlyarm.com/Forum/viewtopic.php?f=47&t=264#p794
I never did that with the Neo, it is easy with the M1 because that has builtin microphone.
Hermann.
Hi Hermann. I would like to ask you a thing. You compiled ffmpeg inside the board, but how to build it in a desktop system using the friendly arm cross compiler?
G
I only once did cross compile the kernel modules successfully:
http://www.friendlyarm.com/Forum/viewtopic.php?f=47&t=240#p801
Since most stuff can be either installed or compiled on the board itself I never had the need to cross compile again for Nanopi. Therefore I cannot help on how to cross compile ffmpeg.
But since you can easily compile ffmpeg as described on the board I don't see the need to cross compile it.
Hermann.
Just did ffplay a .mp3 file on M1 with earphones and did run "top" in another shell.
ffplay uses 26% of a single core:
top - 11:09:46 up 17 min,  2 users,  load average: 1.45, 1.19, 0.79
Tasks:  78 total,   1 running,  77 sleeping,   0 stopped,   0 zombie
%Cpu0  :  0.0 us,  3.1 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu1  : 10.9 us,  1.0 sy,  0.0 ni, 88.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu2  :  4.0 us,  1.0 sy,  0.0 ni, 94.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu3  :  0.0 us,  6.1 sy,  0.0 ni, 93.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem:    507328 total,   126396 used,   380932 free,    14192 buffers
KiB Swap:        0 total,        0 used,        0 free.    61580 cached Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
  375 root      20   0  124324   6764   3860 S  26.3  1.3   0:57.33 ffplay
  414 root      20   0    2804   1020    712 R   2.9  0.2   0:04.07 top
$ bc -ql
400-96.9-88.1-94.9-93.9
26.2
Hermann.
