M1: display stays dark
I have installed the default debian image on an SD card, the M1 boots normally and I can log in via ssh.
However, the display that I attached to the HDMI port stays dark. It does detect that it is plugged in, but there is no signal, not even a console.
An X server is started on vnc, which is not quite what I want.
What is the way to go to get something displayed on the device's own display?
Ok, now I have tried the same with a colleages M1 with the same result: no image.
Could anyone tell me whether connecting a Full HD (1080p) display via HDMI should display a console? If not - how do I get an X server to run on the standard Debian image?
On the other hand - if a console should be displayed out of the box - did we really receive two defective boards?
No problem on my Debian NanoPC-T3 with external display.
Might be helpful to connect up the UART port using a PSU-ONECOM and run minicom on a host computer and watch the bootup messages.
You can stop the boot process and look at bootargs, maybe there is a clue in there.
Thanks for your reply.
I hooked up a serial adapter to the debug port and looked at the output (The entire transcript is in the attachment).
So far, I have not found what causes the trouble, but others seem to have power supply issues that lead to similar symptoms. I will investigate this further.
I have no Allwinner experience, but
[ 19.965201] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536
the ID looks suspect? Are you using a recommended display?
Power supply probably OK, normally poor supply results in repeated re-boots.
The screen ID is a little strange indeed. I did not know about any "recommended" displays. Mine is a Samsung 21 '' full hd monitor attached via an hdmi-to-dvi cable.
In the meanwhile, I found that I can get the display to work using armbian. I will try using the script.bin file generated there.
