How to include custom app in Lollipop source build?
Hi all,
I would like to include a custom app (apk) when I build the Android 5 source for NanoPC T2.
I followed the procudure below and then compiled and booted the img ok, but the app is not installed. FYI - the apk is called ControlCenter and it is signed with the supplied platform keys.
Procedure:
Created device-partial.mk in ~/android5/vendor/isenzo/apps
Created Android.mk in ~/android5/vendor/isenzo/apps/prebuilt/ and copied ControlCenter.apk into the same folder
device-partial.mk contents:
# FriendlyARM apps
PRODUCT_PACKAGES += \
   ControlCenter
Android.mk contents:
LOCAL_PATH := $(call my-dir)
ifeq ($(TARGET_BOARD_PLATFORM),slsiap)
include $(CLEAR_VARS)
LOCAL_MODULE := ControlCenter
LOCAL_MODULE_PATH := $(TARGET_OUT_APPS_PRIVILEGED)
LOCAL_MODULE_SUFFIX := $(COMMON_ANDROID_PACKAGE_SUFFIX)
LOCAL_MODULE_CLASS := APPS
LOCAL_MODULE_OWNER := isenzo
LOCAL_MODULE_TAGS := optional
LOCAL_SRC_FILES := ControlCenter.apk
LOCAL_CERTIFICATE := platform
include $(BUILD_PREBUILT)
endif
I had a similar issue and I ended up putting it in the vendor/friendly-arm/apps/prebuilt directory and modifying the .mk files to include it.
Hi v8dave,
I tried your approach but still no luck.
When you modified the .mk file, did you create your own entry or did you copy/modify an existing entry?
Would you mind sharing the .mk file so I can see if I am using the same terms?
Thanks to v8dave's answer and some further experimentation, I managed to include my apk when building from source.
Steps:
Place the custom APK in the following directory: /vendor/friendly-arm/apps/prebuilt
Add the following code to /vendor/friendly-arm/apps/prebuilt/android.mk
LOCAL_MODULE := myapp
LOCAL_MODULE_OWNER := friendlyarm
LOCAL_SRC_FILES := myapp.apk
Add the app name to /vendor/friendly-arm/apps/device-partial.mk
# FriendlyARM apps
   libfriendlyarm-hardware \
   iTest \
   myapp
