BT won't start on Nanopi M4 Android 8.1
With prebuilt Android 8.1 on nanopi m4, Bluetooth won't enable. Popup says BT failed continuously.
Do you have any work around?
Same problem here for me! It is crashing constantly and the popup window that keeps opening all the time really is annyoing.
Hope there will be a fix soon.
Thanks for your reply! However, I do not really get, what your solution is by using the eFlasher tool.
Do you mean to compile and flash our own version of Android? What needs then to be done differently to the stock Android to get the bluetooth working?
Thanks for any advice!
I have the same Problem at the Nanopi neo4 with Android 8.1
