Neo GPIO on Xiaomi phone
The new Xiaomi Redmi Note 4 carries on the appearance plan of the past Redmi items, and it accompanies the large limit 3GB RAM. Also, it is arranged with an incredible processor Helio X20. At this article, I will show you more insights concerning it. The substance includes four sections, including plans and shows, arrangement and determinations.
check here: https://androidphatloc.weebly.com/
Plans and Shows
It has a metal unibody plan. Other than the 5.5-inch full HD show with the 2.5D bended glass, it gives a decent holding feeling. In the upper center region of the back cover, there is the camera focal point and unique mark sensor. Incidentally, it offers you three tones alternatives, including Gray, Silver and Gold.
In addition, the presentation utilizes the new advances to adjust differentiation and brilliance to its environmental factors. Particularly when you use it in the sun, it gives an astounding client experience. On the off chance that you use it at evenings, you can change it into the Night Display, it will present to you a more open to feeling in perusing the sites, watching recordings or perusing an EBook.
Design
It accompanies a ground-breaking deca-center 64-bit MTK Helio X20 processor running at 2.1GHz alongside a 700MHz Mali T880 MP4 GPU for designs. Also, it runs on Android 6.0 Marshmallow OS with MIUI 8. With respect to RAM and capacity, it has two adaptations. One variant is 3GB of RAM and 64GB of capacity. While another is 2GB or RAM and 16GB of capacity. Coincidentally, the outside memory bolsters up to 128GB.
original site: https://phatlocmobile.vn/
Additionally, it is designed with double cameras, including a 5MP front camera and a 13MP back camera. It underpins 1080p/720p video recording and 720p Slow Motion video recording.
Aside from that, it highlights Hybrid Dual Sim with Dual Standby, Mi-Cloud Storage and 4G+ organization and VoLTE. Inherent a Lithium-Polymer 4,100mAh battery, it upholds one-day typical utilizing in a solitary charge. Also, it underpins quick charging.
Determinations
Gadget Type: Android Smartphone CPU: Deca-Core (4×2.0GHz ARM Cortex-A53 + 4×1.4GHz ARM Cortex-A53 + 2×2.1GHz ARM Cortex-A72) Chipset: MediaTek Helio X20 MT6797 GPU: ARM Mali-T880 MP4, 700MHz Camera: 13 Megapixels Rear Camera With Dual-LED Flash | 5 Megapixel Front camera Memory: RAM-2GB/3GB| ROM 16GB/64GB outer memory uphold up to 128GB (Uses Sim 2 Slot) Display: Screen size 5.5 inches FHD (1080 x 1920 Pixels) Display Battery: Non-Removable Lithium-Polymer 4,100 mAh battery SIM: Hybrid Dual SIM (Micro-SIM + Nano-SIM/microSD) Smartphone Sensors: Proximity Sensor, Accelerometer, Hall, Ambient Light, Gyro,Fingerprint Color: Gray, Silver, Gold Operating System: Android 6.0 Marshmallow with MIUI 8 Dimensions: 151 x 76.3 x 8.35 mm Weight: 175 Grams
my response: https://phatlocmobile.vn/thay-kinh-cam-ung-dien-thoai-xiaomi
End
Xiaomi Redmi Note 4 is the center reach cell phone with a moderate cost. In the event that you are looking for such a cell phone, you can have an attempt!
if what you are trying to do is to deal with the GPIO pins then i would recommend using WIRINGPI library it is written in C.
as for what you asked, m sorry i have no experience in python libraries.
