Expansion Port and PCI-E
Hi. NanoPi M4 has an GPIO 24pin header with PCI-E 2x support. Is there any adapter or hat: GPIO -> PCI-E slot?
Soon there will be a hat for Sata http://wiki.friendlyarm.com/wiki/index.php/NanoPi_M4_SATA_HAT.
But iron is not the most important thing ... the most important thing is software support, and there are problems with it (
I'm still trying to solve the compatibility problem by means of such a solution.
And so far there is only one result - I don’t know if it works or not, as it’s not programmatically supported at all.
I would also like a GPIO2 adapter to M.2 M-Key PCI-e x4 to carry an SSD,
and could the nanopi-m4 boot from an SSD drive ?
