NanoPi-NEO-AIr not seeing NanoHAT PCM5102A
If I do this it come back like this:
root@NanoPi-NEO-Air:/home/pi# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 1: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
  Subdevices: 8/8
card 1: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
  Subdevices: 8/8
card 2: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
card 3: allwinnerhdmi [allwinner,hdmi], device 0: 1c22800.i2s-i2s-hifi i2s-hifi-0 []
  Subdevices: 1/1
I thought it my be the hat but I have another one and I switch it and I get the same thing so it must be the NanoPi-NEO-Air. I had to solder the pins on it and I looked at them real good and they seem like they are all good. The RS232 works on it that's how I got this text. But do have it on WiFi too.
Any one know what could be wrong?
The green LED is lit on the sound board. I guess that says it should be working.
you need the right linux image with support for the pcm5102a hat.
which image do you use?
you could also take a look here:
https://forum.armbian.com/topic/9009-in ... nline-4xx/
I used "nanopi-neo-air_eflasher_friendlycore-xenial_4.14_armhf_20181120.img" does this one support the PCM5102A?
As it booted up I seen:
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
So I did that and got this back:
root@NanoPi-NEO-Air:~# systemctl status systemd-modules-load.service
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; ven
Active: failed (Result: exit-code) since Sat 2019-01-26 10:40:18 UTC; 58s ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 226 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=
Main PID: 226 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomple
I guess it does mean that this kernel don't work with the PCM5102A sound hat.
Can a do some modprobe something like that?
did you enable I2S0 and the PCM5102A with npi-config like written in the Wiki about the PCM5102A?:
http://wiki.friendlyarm.com/wiki/index. ... 4.x_Kernel
I got it working!
Looked at http://wiki.friendlyarm.com/wiki/index.php/NanoHat_PCM5102A
Starting at "5.2 Under H3/H5 & Linux-4.x Kernel" I did npi-config and picked how they show in the photos there. Rebooted and did aplay /root/Music/test.wav -D plughw:4 and it plays music now.
Not sure why it install it as card 4.
Did not have to change the kernel looks like.
Wow we must of post this at about the same time.
Got the sound working but now I am trying to get squeezelite to work on this. But when I go to list all the devices it don't show card 4. It looks like this:
root@NanoPi-NEO-Air:/# squeezelite -l
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
default
sysdefault:CARD=Dummy - Dummy, Dummy PCM - Default Audio Device
dmix:CARD=Dummy,DEV=0 - Dummy, Dummy PCM - Direct sample mixing device
dsnoop:CARD=Dummy,DEV=0 - Dummy, Dummy PCM - Direct sample snooping device
hw:CARD=Dummy,DEV=0 - Dummy, Dummy PCM - Direct hardware device without any conversions
plughw:CARD=Dummy,DEV=0 - Dummy, Dummy PCM - Hardware device with all software conversions
sysdefault:CARD=Loopback - Loopback, Loopback PCM - Default Audio Device
front:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - Front speakers
surround21:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - 2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - 4.0 Surround output to Front and Rear speakers
surround41:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - 4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - 5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - Direct sample mixing device
dmix:CARD=Loopback,DEV=1 - Loopback, Loopback PCM - Direct sample mixing device
dsnoop:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - Direct sample snooping device
dsnoop:CARD=Loopback,DEV=1 - Loopback, Loopback PCM - Direct sample snooping device
hw:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - Direct hardware device without any conversions
hw:CARD=Loopback,DEV=1 - Loopback, Loopback PCM - Direct hardware device without any conversions
plughw:CARD=Loopback,DEV=0 - Loopback, Loopback PCM - Hardware device with all software conversions
plughw:CARD=Loopback,DEV=1 - Loopback, Loopback PCM - Hardware device with all software conversions
sysdefault:CARD=Codec - H3 Audio Codec, - Default Audio Device
dmix:CARD=Codec,DEV=0 - H3 Audio Codec, - Direct sample mixing device
dsnoop:CARD=Codec,DEV=0 - H3 Audio Codec, - Direct sample snooping device
hw:CARD=Codec,DEV=0 - H3 Audio Codec, - Direct hardware device without any conversions
plughw:CARD=Codec,DEV=0 - H3 Audio Codec, - Hardware device with all software conversions
sysdefault:CARD=allwinnerhdmi - allwinner,hdmi, - Default Audio Device
dmix:CARD=allwinnerhdmi,DEV=0 - allwinner,hdmi, - Direct sample mixing device
dsnoop:CARD=allwinnerhdmi,DEV=0 - allwinner,hdmi, - Direct sample snooping device
hw:CARD=allwinnerhdmi,DEV=0 - allwinner,hdmi, - Direct hardware device without any conversions
plughw:CARD=allwinnerhdmi,DEV=0 - allwinner,hdmi, - Hardware device with all software conversions
sysdefault:CARD=I2Smaster - I2S-master, - Default Audio Device
dmix:CARD=I2Smaster,DEV=0 - I2S-master, - Direct sample mixing device
dsnoop:CARD=I2Smaster,DEV=0 - I2S-master, - Direct sample snooping device
hw:CARD=I2Smaster,DEV=0 - I2S-master, - Direct hardware device without any conversions
plughw:CARD=I2Smaster,DEV=0 - I2S-master, - Hardware device with all software conversions
DEV=0 or 1 but never any thing saying DEV=4
Is there a way to fix this?
whats the output of
aplay -l
and what is the content of your /etc/asound.conf ?
Sometimes after installting the pcm5102a - in mainline armbian - and reboot my pcm5102a changed from Card 0 to Card 1:
root@npi-neo(192.168.6.24):~# aplay -l
card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
card 1: I2Smaster [I2S-master], device 0: 1c22000.i2s-pcm5102a-hifi pcm5102a-hifi-0 []
  Subdevices: 1/1
my /etc/asounf.conf :
root@npi-neo(192.168.6.24):~# more /etc/asound.conf
pcm.!default {
    type hw
    card 1
    device 0
ctl.!default {
    type hw
    card 1
The out put is this:
root@NanoPi-NEO-Air:~# aplay -l
XDG_RUNTIME_DIR (/run/user/1000) is not owned by us (uid 0), but by uid 1000! (This could e g happen if you try to connect to a non-root PulseAudio as a root user, over the native protocol. Don't do that.)
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 1/1
Subdevices: 1/1
card 4: I2Smaster [I2S-master], device 0: 1c22000.i2s-pcm5102a-hifi pcm5102a-hifi-0 []
Subdevices: 1/1
The file /etc/asound.conf looks like this. Wow says card 4 I will change it to 0 and maybe that will work.
pcm.!default {
type hw card 4
ctl.!default {
type hw card 4
I copied what you had in the /etc/asound.conf file and rebooted.
But it still says card 4 like this:
Welcome to Ubuntu 16.04.5 LTS 4.14.52
System load: 1.22 Up time: 5 min Local users: 2
Memory usage: 52 % of 491Mb IP: 192.168.86.250
CPU temp: 42°C
Usage of /: 10% of 29G
* Documentation: http://wiki.friendlyarm.com/Ubuntu
* Forum: http://www.friendlyarm.com/Forum/
Last login: Sat Jan 26 08:48:18 2019 from 192.168.86.54
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
I checked the /etc/asound.conf and it's still how I changed it to what you have.
Got this because I want to install it in a sound bar. But have to get it working good 1st.
I can play a song like this:
mpg123 '/home/odroid/Audeo/4 nice songs/02 - Fun Fun Fun.mp3' -D plughw:4
But I am trying to get it to work with squeezelite I don't get why it's not listing the Pcm5102a,DEV=4
root@NanoPi-NEO-Air:~# squeezelite -l
Output devices:
pulse - PulseAudio Sound Server
It list a lot but none are DEV=4
I don't know how it get's it's device list. Maybe it can't go up to 4 only 0 and 1 not sure.
Output devices:
isnt that device-name useable without device-numer?
in this thread they used on a RPi the follwoing name for a card:
~/squeezelite $ ./squeezelite -o sysdefault:CARD=GenericRJ -a 20:4:16:1 -s 192.168.1.13
"16" in -a 20:4:16:1 means force 16 bits
With Squeezelite I get a software volume
0 => no sound
1=> sound not weak, noisy
from around 12, the sound become less noisy but it is already very loud
20=> is close to max before the amp clips
