Hdmi display
There is a lot of cheap 10.1 inches lcd on market, often have a resolution of 1280 x 800.
I connected this lcd with h3disp using the mode of 1280 x 720 (720i).
Everything works, but aspect ratio is wrong. (800->720)
Is there a fast and simply possibility to set 1280x800 resolution in Armbian?
Simple solution is by using mainline kernel. It should work OOB.
For 3.4.y you need to DIY https://forum.armbian.com/topic/3199-hd ... 00-display
In total there are 40 users online :: 0 registered, 0 hidden and 40 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 40 guests
