Ubuntu Mate 18.04 build.
So friends ... let's talk about Ubuntu 18.04 "Core" and its further transformation into Mate.
Next, I will point out all the steps to get a normally functioning (of course, this is quite a bold expression) PC with the "Mate" desktop. So start:
$ sudo apt-get update
$ sudo apt-get install bash-completion
$ sudo reboot
$ sudo service hostapd stop
$ sudo apt-get autoremove hostapd
$ sudo apt-get upgrade
$ sudo apt-get dist-upgrade
At this stage, we updated the system and removed the buggy HOSAPD, which in future will bring only disappointment)
Let's start installing the MATE working environment:
$ sudo apt-get install ubuntu-mate-desktop
$ sudo reboot
After a reboot, we will encounter some errors, they are easily corrected:
"org.freedesktop.DBus.Error.Spawn.ExecFailed" - ERROR 1
$ sudo chmod 4754 /usr/lib/dbus-1.0/dbus-daemon-launch-helper
$ sudo chown root:messagebus /usr/lib/dbus-1.0/dbus-daemon-launch-helper
$ sudo reboot
"org.freedesktop.DBus.Error.Spawn.PermissionsInvalid" - ERROR 2
And there seems to be no more errors, but shortcuts or folders are not displayed on the desktop, this is treated by installing the following packages:
$ sudo apt-get install xserver-common
$ sudo apt-get install xserver-xorg-core
$ sudo apt-get install xserver-xorg-legacy
$ sudo reboot
Next you need to remove or add the necessary software, just for you.
Sincerely, Pavel.
small update - during Mate installation symbolic links to OpenGL ES/EGL hardware libs was changed to Mesa software lib.
Works great, thanks for posting this.
Hi Pavel, thank you for the hint... I just tried your method on the newest:
rk3399-eflasher-friendlycore-bionic-4.4-arm64-20181219.img
but got stuck when installing ubuntu-mate-desktop....
Also apparently they fixed the buggy hostapd so I did your procedure anyway but maybe it is not needed anymore.
Well if you have any hints on how to workaround those unmet dependencies... should I try force installing them one by one?
pi@NanoPi-M4:~$ sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
xserver-common xserver-xorg-core xserver-xorg-legacy
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
pi@NanoPi-M4:~$ sudo apt-get install ubuntu-mate-desktop
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ubuntu-mate-desktop : Depends: mate-desktop-environment-core but it is not going to be installed
Depends: ubuntu-mate-core but it is not going to be installed
Recommends: folder-color-caja but it is not going to be installed
Recommends: gvfs-fuse but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Hello Pavel,
I tried to go down further but got stuck with the gvfs:
pi@NanoPi-M4:~$ sudo apt-get install gvfs-backends
gvfs-backends : Depends: gvfs (= 1.36.1-0ubuntu1.1) but 1.36.1-0ubuntu1.2 is to be installed
Depends: gvfs-daemons (= 1.36.1-0ubuntu1.1)
Depends: gvfs-libs (= 1.36.1-0ubuntu1.1) but 1.36.1-0ubuntu1.2 is to be installed
Depends: gvfs-common (= 1.36.1-0ubuntu1.1) but 1.36.1-0ubuntu1.2 is to be installed
:roll: :roll: :roll:
tuation.
Hi.
There is a possible solution to this problem:
1. $ sudo apt-get update
$ sudo reboot
2. $ sudo apt-get upgrade
3. $ sudo apt-get upgrade
It is important to reboot after Update.
it was worth trying...update reboot and then upgrade.... but unfortunately.. no change...
Did you manage to do it on the new available core image?
Hello, theshade .
Now I have not tried to collect Mate on the newest version of the system.
The other day I will definitely try and write about the results.
Try using a "kernel" image labeled "SD", i.e. for direct recording to an SD card and follow-up work from it, without an MMC card (at least for a while).
Ok I will try.. I was using the mmc so far... I thought both were identical....
I am a completely new Linux user and I had the same problem as you but when searching the internet I came to aptitude thanks to this command everything started working
I am running into the following issue when attempting to install Ubuntu Mate on the
rk3399-sd-friendlydesktop-bionic-4.4-arm64-20181219.img on an SDXC UHS-1 U3 card
> viewtopic.php?f=62&t=2036
sudo apt install ubuntu-mate-desktop
ubuntu-mate-desktop : Depends: cups-browsed but it is not going to be installed
Depends: cups-core-drivers
Depends: cups-filters-core-drivers but it is not going to be installed
Depends: cups-ppdc
Depends: printer-driver-gutenprint but it is not going to be installed
Depends: printer-driver-hpcups but it is not going to be installed
Depends: printer-driver-postscript-hp but it is not going to be installed
Recommends: bluez-cups but it is not going to be installed
Recommends: cups
Recommends: cups-bsd
Recommends: cups-client
Recommends: cups-filters but it is not going to be installed
Recommends: hplip but it is not going to be installed
Recommends: printer-driver-foo2zjs but it is not going to be installed
Recommends: printer-driver-m2300w but it is not going to be installed
Recommends: printer-driver-pxljr but it is not going to be installed
Recommends: printer-driver-splix but it is not going to be installed
Recommends: smbclient but it is not going to be installed
The issue appears to be this
Depends: libcups2 (= 2.2.7-1ubuntu2.2) but 2.2.7-1ubuntu2.3 is to be installed E: Unable to correct problems, you have held broken packages.
Any help?
Well friends ... FriendlyARM threw another riddle :)
After the release of the new distribution kit (on the old kernel 4.4.143), errors occur when installing Mate Desktop. Let's fix them:
1. $ sudo apt-get autoremove gvfs
This will remove the “broken version” of GVFS and allow you to install Mate-Desktop.
After installation it is possible that pulseaudio will "fall off", I have not cured it yet (the audio registration icon on the panel is not displayed).
As new bugs are eliminated, I will add this post.
Removal of gvfs allowed install of the Mate desktop, thanks for that. As for the Pulseaudio, it seems to be installed but does not show up in any of the menus and no icon on the panel. It is shown as an auto-started application but no sign of it.
Well Onlinesbi sudoku incometaxindiaefiling if you have any hints on how to workaround those unmet dependencies... should I try force installing them one by one?
