NanoPC-T4 Memory frequency
Whats the memory frequency of the NanoPC-T4? Can I change it (overclock it)?
Wiki says its
RAM: Dual-Channel 4GB LPDDR3-1866
but the wiki also says its 2ghz, but its not that either. So ideally I could read this from the terminal somehow.
Check your ram chips. It's writen onto it which chips it are. Type that into google and you'll know.
It can be that not all ramchips on T4's are all the same.
I think hwinfo can give this info.
sudo apt install hwinfo
sudo hwinfo
or
sudo apt install hardinfo
hardinfo
That should mean it's clocked at 933Mhz.
