NanoPc and DietPi
After having some troubles with an early Lubuntu image, I decided to give DietPi a try and must say it runs great! I just got Handbrake to work and I'm now encoding DVD's on the Nanopc. Love this box way more now that it works pretty stable.
avensis wrote:
Personally I tested Volumio and DietPi: I started with Volumio at the beginning and finally I stayed at DietPi because a lot easier to set up: it is light and efficient.
Now compare with Armbian which will run from faster to much faster (depending on application). It is also lighter, cleaner, comes with end user support, build engine and without diet-bloat-spyware.
avensis wrote:
Personally I tested Volumio and DietPi: I started with Volumio at the beginning and finally I stayed at DietPi because a lot easier to set up: it is light and efficient. https://emilydavinci.com
____________________________________________________
This will not allow to go beyond seriously.
