USB 2.0 Host controller crashes in Android.
I've been using this board for awhile now and just ran across an issue with USB. After some time (sometime hours, sometimes minutes) the devices disappear and I see the following message in the kernel messages:
[ 3893.229656] ohci-platform fe3a0000.usb: frame counter not updating; disabled
[ 3893.229760] ohci-platform fe3a0000.usb: HC died; cleaning up
[ 3893.230128] usb 6-1: USB disconnect, device number 2
[ 3893.470920] binder: 436:637 transaction failed 29189/0, size 348-0 line 2880
[ 6585.522466] ohci-platform fe3e0000.usb: frame counter not updating; disabled
[ 6585.522575] ohci-platform fe3e0000.usb: HC died; cleaning up
[ 6585.523002] usb 2-1: USB disconnect, device number 2
It looks like the host controller is hanging and the kernel is disabling it. Since our product relies on USB we really need this to work. Any ideas on what I can do fix this?
Thanks,
Mike
So nobody at FriendlyElec reads these? Was hoping for an update...
Thanks,
Mike
For anyone else having this issue, I found a patch that seems to fix it.
https://lore.kernel.org/patchwork/patch/880379/
I had to tweak it a little to patch against the kernel version in the android source, but after weeks of leaving the system on I no longer loose USB ports.
Mike
