PMU
PMU
Is there anyproduct can drive and recharge lipo batteries ?
Unfortunately none of our existing boards can support that
Need info NANOpi M2 PMU Li-ion batt powering
How is activate PMU Whit Li batt for boad powering
friendlyarm do you planning Help
I have a nanopi m2 board include AXP228 PMU and I see M2 board and schematic pmu Li ion batt charge pads
placed on board and I solder these pads Li-ion batt after
when I press WakeUp butt instandly Green led on then other leds on after one second system all off
May be need new kernel for board working Li batt.
dear friendly arm
please make pmu battery charge enable nw Kernel and release
could you helps NANopi m2 owner
why
if make new kernel enable axp batt charge it is not solve charge/powering board via li ion batt (in kernel config file)
which your board support real batt powering
