Q: New (v1.1) Neo2 now allways be with soldered Header-Pins?
Will the new (v1.1) Neo2 (non Plus or Core) now allways be with soldered Header-Pins? -
because there is no ordering option (like on the normal Neo) for with or without Pins.
Will it work in the silver NAS-Case?
Is the 1GB RAM option available or only for future use?
At the product page the "new" 512MB version will be a V1.1?
http://wiki.friendlyarm.com/wiki/index. ... hange_List
Would the 1GB version also v1.1 or is it v1.0?
March-20-2018
Updated sections 4, 9 and 10 = new/additional Pinout
Added section 11 = Hardware_Change_List
Is it anywhere available detailed list of changes in 1.1 and when it will be possible to buy it?
differences are written here:
- NanoPi NEO V1.1 1711's Audio connector is a 2.54mm 4Pin-header
- NanoPi NEO V1.1 1711's Ethernet port is a pin connector.
- NanoPi NEO V1.1 1711 has a CVBS output which V1.0 doesn't have
- NanoPi NEO V1.1 1711 has two more mounting holes of 1.7 mm in diameter
- NanoPi NEO V1.1 1711 has 1.1V/1.3V GPIO voltage regulation
and
- Popup TF Card Slot
Is it anything known when this version will be available in online shops?
NEW NEO2-512M is in Stock
