NaniPI NEO plus 2 bootloop
I started my nanopi from pendrive containing armbian, upgraded it (which unfortunately also upgraded u-boot apparently)
and after rebooting it loops over:
U-Boot SPL 2017.11-armbian (Jan 24 2018 - 11:07:32)
DRAM: 1024 MiB
Trying to boot from MMC2
NOTICE: BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE: Configuring SPC Controller
NOTICE: BL3-1: v1.0(debug):aa75c8d
NOTICE: BL3-1: Built : 11:07:27, Jan 24 2018
INFO: BL3-1: Initializing runtime services
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
INFO: PSCI Affinity Map:
INFO: AffInst: Level 0, MPID 0x0, State ON
INFO: AffInst: Level 0, MPID 0x1, State OFF
INFO: AffInst: Level 0, MPID 0x2, State OFF
INFO: AffInst: Level 0, MPID 0x3, State OFF
Is there any way I can stop it and enter new/correct env to boot from emmc or anything else?
DRAM: 1024 MiB
The repository was fixed but that is too late for you. Now you need to boot with SD card and update manually :(
This is the file you need:
http://apt.armbian.com/pool/main/l/linu ... _arm64.deb
Those are instructions:
https://forum.armbian.com/topic/6299-pr ... ment=48195
thanks. Booting from SD card actually still worked so that was enough for me :)
