NanoPi Duo - Ethernet over USB OTG
I'm trying to connect from my Linux machine to my NanoPi Duo over USB OTG using ethernet module.
I have loaded g_ether module:
root@NanoPi-Duo:~# lsmod
nls_ascii              16384  1
xradio_wlan           110592  1
g_ether                16384  0
I see it as Ethernet device from my Linux machine:
# lsusb
Bus 001 Device 010: ID 0525:a4a2 Netchip Technology, Inc. Linux-USB Ethernet/RNDIS Gadget
On both machines
# ls /sys/class/net
Lists usb0
I run following command on my Linux machine to start communication, but get:
# pump -h usbether -i usb0 --no-dns --keep-up --no-resolvconf --no-ntp
Operation failed.
Some other information:
root@NanoPi-Duo:~# dmesg | egrep "usb0|g_ether"
[    3.299153] usb0-vbus: disabling
[   12.166744] usb0: HOST MAC 1a:a8:b0:57:dd:70
[   12.171312] usb0: MAC 06:40:18:06:db:a1
[   12.189331] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[   12.196003] g_ether gadget: g_ether ready
[   12.829197] g_ether gadget: high-speed config #1: CDC Ethernet (EEM)
root@NanoPi-Duo:~# ifconfig usb0
usb0      Link encap:Ethernet  HWaddr 06:40:18:06:db:a1
          BROADCAST MULTICAST  MTU:1500  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
What I'm missing? Ethernet over OTG with my mobile phone worked w/o any issues.
Thanks,
Gedas
Answering to my question as I managed to solve it :)
`pump` command is not needed. What did help is adding to /etc/network/interfaces:
allow-hotplug usb0
iface usb0 inet static
        address 192.168.7.2
        netmask 255.255.255.0
        network 192.168.7.0
        broadcast 192.168.7.255
        gateway 192.168.7.1
On both machines, just with different IPs. .1 on host, and .2 on OTG.
