Thrown out on SSH login
I'm trying to log into a NanoPi 2 for the first time. Have written nanopi2-debian-sd4g-wifiap.img to a 16G SanDisk card, and powering it through the micro-USB port. So far so good, I see the access point, and can attach to it.
When I connect via "ssh -l root 192.168.8.1" with password "fa", it seems to accept, but then throws me out:
packet_write_wait: Connection to 192.168.8.1: Broken pipe
In verbose mode, I see this (initial part omitted):
debug1: Authentications that can continue: publickey,password
debug1: Trying private key: /Users/jcw/.ssh/id_dsa
debug1: Trying private key: /Users/jcw/.ssh/id_ecdsa
debug1: Trying private key: /Users/jcw/.ssh/id_ed25519
debug1: Next authentication method: password
root@192.168.8.1's password:
debug1: Authentication succeeded (password).
Authenticated to 192.168.8.1 ([192.168.8.1]:22).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
Is there a way to get past this problem? This is my first attempt ever to try out the NanoPi 2.
-jcw
Hi what terminal did you login to your Pi 2 from? We tried that from a host running Ubuntu 14.04 and it worked. Since this was a communication process between your terminal and the Pi 2 we suspect that this issue might be associated with your terminal.
