CM3588 NAS Kit - I2C via GPIO
Hi.
I'm using official OpenMediaVault software with NAS kit which has been installed on eMMC.
According to the doc (wiki page) there is one I2C located on GPIO header. In the CM3588 NAS SDK Schematic pdf I've found that SDA=Pin3 and SCL=Pin5. I'd like to use it for OLED screen. I do have some experience with the very same OLED screen connected to ESP32C3 and RP2040 so I'm sure it's working fine.
However I believe that I2C on the CM3588 is not enabled by default as I don't see any changes when using sudo i2cdetect -l with OLED screen connected to and disconnected from the GPIO header.
I can't find anything similar to raspi-config (RaspberryPi) nor to orangepi-config utilities. Does one exist for CM3588 NAS Kit?
How can I enable I2C then? /boot/ folder does not contain any kind of config.txt file but two subdirectories only: firmware, which contains only binary blobs, and grub.
I will be grateful for any help.
I did not find a solution either. Anyhelp will be wonderfull!
Still need help!
If the board firmware supports it, enabling the correct I2C overlay for the GPIO pins (SDA pin 3 / SCL pin 5) should expose the bus (usually /dev/i2c-1).
You might also want to check the board documentation or SDK for device-tree overlay examples, since many Rockchip-based boards require enabling peripherals that way.
Hope this helps.
In total there are 42 users online :: 0 registered, 0 hidden and 42 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 42 guests
